- Sep 2, 2013
- 5,418
Can anyone enlighten me on how to remove the components on the knee crank shaft? Got the shaft assembly out and the gear and bearing off the drive end, but having no luck on the crank end. There is a Woodruff key on the shaft inside the steel collar that I thought might be the issue, but there isn't enough room between the shaft and the inside of the collar to remove it. There is also a partially drilled hole in the collar that looks like it would be for a set screw, but doesn't go all the way through, and isn't threaded. Tried setting it up in the press, but no movement, and I was afraid to crank up the pressure for fear of breaking the pot metal/alum retainer. The gear and bearing on the other end pressed out very easily. Any help much appreciated. Thanks, Mike
