Hi all,
I have just put down a deposit for a used King Rich or KRV or XYZ mill.
My shop does not have three phase and I loath to use a rotary phase converter. So I am going to use an invertor aka VFD. The motor name plate says 2.2kW 415V.
For this to work well with torque through out the range of speeds, I need to rewire the phases such that they can run 3x 240V and not 3x 415v. That is the easy bit...IF the motor is easily rewired like some newer motors are.
My question to you all is if anybody has one of these machines with the Tong Fu Taiwanese motor could they take a photo of the inside of the housing that the power cables connect to on the motor and post?
Thanks in advance!
Thanks in advance!
