I wish I knew what you mean by 'vise hold down'. I can see making an obnoxiously shaped guide - but why? I must be better off finding the usual key cutters.
May be a surface broach, they are made to fit different machines with particular mounting requirements.
Do not be constrained by the commonly known methods such as a bushing in a hole that the tool passes through to form an internal key seat or a simple round hole that will accept a polygonal broach that produces any number of sides and shapes. Surface broaching is fairly common in manufacturing. https://www.mhi-machinetool.com/en/products/detail/broach.html
