drawers come out easy. however, not so with the pulls. this is a older box , and, the pulls are attached a different way than what is used now. there is a guide plug on one side and the other has a split piece of steel; that wen the pull is pressed in the split piece is seperated apart and i guess lightly pounded to make the pull tight. tried on one pull and the steel is very difficult to pinch back together. wasn't able to do so yet.. i would think that pinching the piece back together will result in some breaking. have to put my thinking cap on. worst case i can fabricate new pulls out of aluminum and screw them on. not original, but, will look ok
