Hello all,
A member here posted a way to cut dovetails without using a standard 60 deg dovetail cutter " sorry I could not find the thread but if you see this post thanks for the idea" . Seeing that KDK went out of business and the only source for additional blocks is Ebay or the Chinese I decided to make my own from 1.5 x 1.5 12L14. I measured the dovetails with some .375 dowel pins and laid out the dimensions in autocad, I thought everything should be ok as the drawings matched the KDK part. but the first prototype showed that the dovetail was .0015 to wide and the cam handle travelled to far, readjusted the cad drawings and the second part fit perfect, so on with the photos. Jig to hold tool block for end cut
Jig mounted on Kurt vise holding tool block
Jig for holding tool block at 60deg
Power tapping the last of 160 5/16 x 24 holes
Stage one complete, on to cutting dovetails
Clearance slots completed for dovetails
10 tool blocks nearing completion
Cutting the first 60 deg angle using a .25 end mill
Cutting the second 60 deg angle using .25 end mill
Dove tails completed
Cut the pockets, for setting the height of the tool block
1/4 x 28 holes for set screws counter bored drilled and tapped
Finally the tool block mounted on the holder.
