I'm thinking about variable speed control for my G0709. I had thought about 3Ø. But last night I had another idea...
I have an unused 3HP 90V 22A brushed DC motor (intended for a heavy-duty treadmill) for historical reasons. It looks like the KBPC-225D would be a good controller for this motor. Seems like a better idea than a treadmill controller transplant. I would have to make up mounts and probably new pulleys because I doubt the shaft is the same, but it doesn't seem obviously crazy. Has brake function, optional forward/brake/reverse switch. I would have to do an encoder-to-DAC for tachometer input but I would want something to drive a tach display anyway and adding a DAC output for analog speed feedback would be trivial if I'm already doing a digital tach display from optical encoder. That would be less expensive than a 3Ø + VFD with similar benefit. Am I missing a downside?
