- Jan 10, 2019
- 1,220
This can be adapted to any Bridgeport-style mill with a drawbar nut up top.
I use my mill just enough to be bugged by having to constantly loosening the drawbar, to the point that sometimes I don't even when I should. One thing that makes it tougher is that I raised the mill to a more convenient working height, but it raised the drawbar height such that I had to stand on my toes. The project was started in February 2024 and took one month. For this reason, ignore the posting dates below since they're being copied over en masse.
Looking at power drawbar ("PD") kits, the obvious answer was PM's own unit, but being a hypocritical cheapskate, I decided to make my own. After watching many YT videos where everyone uses the Harbor Freight butterfly impact wrench, I went to get one, only to discover that HF has apparently discontinued the tool. That started the wheels turning, could I do something different, and what exactly did I want?
Nearly all homebuilt PDs use compressed air, with many people leave their compressor on all the time. Thing is, my California Air Tool compressor did something once that broke all trust - one day when it was turned, the motor stalled(!), getting very warm very quickly. If it hadn't been shut off; it may well have caught fire because it wasn't drawing enough current to pop the breaker, so it's never left unattended. Between that and not wanting to bother waiting for it to build pressure just to use the PD once or twice, thoughts began to wander. Why hasn't anyone designed a PD using an electric impact wrench? Looking up the specs for what's needed, it appears that only 50-100 ft-lb is needed to tighten an R8 adaptor. Nearly all corded impact wrenches generate far more than this, so much so that I worried that it could either strip the threads or even shear the drawbar itself. Attention then turned to cordless impact wrenches, and they, too, brag about how much torque they can generate. Looking at the lower end of the range though, I came across a DeWalt unit that generates up to 150 ft-lbs, and decided to give it a go. More posts to follow
