In another thread, PeteH from Tarrytown New York made mention of Aero-Kroil from Kano Labs. He indicated that he thought it was the best penetrating oil ever, and in some ways I agree, it is great stuff. Kano bills it as the "oil that creeps" and it does have a way of getting into places that other oils just don't seem to succeed with. Anyway, Pete wanted to know if anyone knew of anything that worked better, so I thought I should mention it in a separate thread.
Keep in mind that what follows are my opinions based on my experiences, I have no connection with either manufacturer, nor with any retailers.
I don't necessarily think that there is anything better than Kroil, but I do believe that there is an equal out there, called K&W Knocker Loose. I first found this brand at a NAPA parts store 20 years ago or so, and it was recommended to me by someone else.
I have found that there are cases where one product excels above the other, as follows:
Where heavy rust and corrosion are the only concerns, I usually use Kroil, and I allow it to soak as long as possible.
In cases where rust is not so heavy, or where old caked grease is an issue, or maybe some light lubrication is required, I use Knocker Loose. It is cheaper than Kroil and much easier to obtain. Works a bunch better than WD-40 or Liquid Wrench.
Just my $.02 Hope that someone else might find it useful.
