This 101.07301 looks to be in pretty good shape (Serial No.: 6L 025657). The gears/threads throughout look to be pretty good, but there are some small chips out of a couple pulley walls on the M6-79 Pulley and Gear with Bushings on the spindle, and a chip out of the M6-80 pulley on the countershaft hanger assembly. I think these chips are small enough that I could live with these while I get it running, and then replace them later.
I may have a franken-lathe, as it appears the Back Gear Assembly is a 2 collar M6-243X, but it may have been missing the M6-255 washer. Also, the Spindle Assembly looks like a 1 roller bearing & bushings spindle, even though everything I see shows 2 roller bearings in all the documentation. Am I on crazy pills here?
The lathe came to me almost fully disassembled, with parts separated into bags. The exception being the headstock: the spindle & back gears were still installed, and seemed to move pretty well, fairly smoothly. I have disassembled this, and put into baggies to manage it all, post a soaking in PB Blaster.
I think it's fairly complete, but I shall find out soon.
Again, the Back Gear Assembly looks like the 243X version with TWO M6-253 collars, but did not have the M6-255 washer...seems like it had the space for that washer...
Parts for Countershaft I might like to replace during reconditioning:
M6-109
L2-682 Collar
Parts for Backgear Assembly I might like to replace during reconditioning:
M6-249 Bushings
M6-253 Collars
M6-255 Washer (or at least share what the specs/material is, for this?) This assembly did not have this washer installed when I disassembled it, and put into bags for inventory management.
Spindle Assembly
M6-71 Dust Covers (or is this a generally available item for that bearing?)
M6-72 Dust Covers (or is this a generally available item for that bearing?)
M6-81B Bearing
M6-82B Bearing
M6-258 Bushing
M6-89 Spacer
I might be able to get away with just a full re-assembly, to get it moving again. What do you all think?
Are these parts available from Clausing, or a 3rd party? I sent a note to them asking about availability, but thought I would engage with you all as well.
I soaked everything in PB Blaster, and it all looks pretty good, the exception being the one bearing off the spindle seems rough to spin now - that maybe a function of the PB Blaster breaking down the lubrication in the bearing.
The machine is at a siblings, so I will get some pictures later this week and post them, but I really don't remember seeing 2 bearings on the Spindle Assembly, so I am freaked out a little, as Im clearly losing it, or it isn't a configuration I have the manuals for...
Is there a trick to removing/replacing the bushings in the pulleys/gears, castings?
any other thoughts or recommendations?
thanks in advance. Im looking forward to the community...
M6-109
L2-682 Collar
M6-249 Bushings
M6-253 Collars
Spindle Assembly
M6-81B Bearing
M6-82B Bearing
M6-258 Bushing
M6-89 Spacer
