Got the saw uncrated and set up today. I'll check blade alignment another day.
First off, the saw was very well packaged and protected. I'm used to seeing this kind of care taken by Matt and the boys at PM, but typically not for items I purchase from Grizzly. The difference may very well be that this saw is made and crated in Taiwan.
Other than removing a shipping strap and unbolting the saw from the pallet there was no assembly required. Fit and finish appear to be very good at first glance as well. Ok, on to some pics...
Like I said, nice packaging. I found this piece in the pan just below the vise. Looks to be a test piece? There was a small amount of cutting chips and fluid/oil on the machine as well. The test cut piece was dirty and had burrs on it so I cleaned it up and measured it at four points with a mic. Just over a thou variance across four points. Wow. Wasn't expecting that.
These last two are where the saw is going to reside in my garage. One, pulled out to work, the other stowed out of the way.
It doesn't take up too much room, but man, I should have bought this thing a couple of years ago when I first saw it (no pun intended). I love the hydraulic feed, and geared speed changes. The quick release vise was a pleasant surprise as well. Once I figured out what it was. At first I though the thing was broken.
And I'm glad I didn't second guess myself and get a larger one. This will cut everything I need to cut, and at 270lbs. it was about all I could do to pick it up off the pallet. This getting old(er) stuff is no fun.
There, you guys happy now?
