- Mar 26, 2018
- 8,756
I finally got off my wallet. I have tried to find steel plate but the cost is just too high. This seems to be a good compromise.
I have a 5' X 5 ' steel top table in the shop.
It has waves in it.
I plan on cutting out a section to insert this Certi-Flat welding table.
To be able to have a flat table that can be used for clamping, tacking, welding will be great.
I built one before the fire (before and after). I like it so much I knew this was always a possibility.
It has waves in it.
ProTop - 36"x48" - Welding Table - WeldTables.com
Transform your welding experience with the Certiflat - 36"x48" ProTop Welding Table. Engineered with tab and slot stiffening ribs, heat control design, and CNC laser cutting technology, this welding table ensures a flat and accurate surface. With +/- .003" precision and compatibility with...
weldtables.com
