So full disclosure, I've had my mill (Van Norman # 12) for more than a year now but I'm just getting to use it more in the last few months and with my starting from zero knowledge base I feel like I'm probably at a senior high metal shop level of skill. But I'm getting better. Thank god for this group and YouTube!
Now my situation. First time using my brand new Shars boring head with my new LMS carbide braised boring bars.
I am making the knurling tool shown on toms techniques channel. He has vids showing the entire project so good project for us beginners.
Boring a 2.06 inch hole from a 1 inch starter hole in one inch thick 6061 aluminum. I chose a bar that was the shortest and stoutest to get through the one inch thick material. Set the cutting edge on outside perimeter with cutting edge on center (I know it creates a small negative rake when set this way but seemed like the most frequent way to solve problem in my reading about boring).
Had a lot of stock to remove so I started taking 30 thou on radius cuts, seemed smooth with no chatter, then went to 40 thou and all still good. Used WD40 for lube.
Cuts seemed to agree with occasional measurement and this is not a critically precise hole so I decided to take the last 24 thou as a final boring. Significantly less than the 30 and 40 thou cuts up till now. Same set up only not as big a bite and almost instant chatter.
Tried more lube, slower feed rate and still chatter. Cleared bottom of hole and came up slowly hoping to clean up some of the chatter but no luck. Hole measures out ok but significant chatter marks.
Help me understand what went wrong? Any ideas?
Started out at around 340 rpm the moved down to around 200 as hole got bigger, mill didn't seem to strain at all on any size cut.
Thanks for your thoughts.
John in Minnesota
Just saw the boring bar primer,
Haven't read it yet. Sorry if the info I'm asking about is in the primer. I will read it soon.
John in Minnesota
