Just finished restore
HillbillyZ
Jan 9, 2020
14
just joined a few days ago, but have read the forum for quite some time.
just finished my restore of an ole Atlas 10 that had all the attachments when I bought it Dec 26, 2019.
need to clean up change gears in pic, but outside that, there is not a single screw, bolt, washer, spring, gear, etc, etc that was not completely disassembled, wire brushed, cleaned, painted, etc, etc on the entire machine. Even has original motor. I cleaned it up, but may have a friend rebuild it completely. Not sure yet. Thing was covered in rust, filth, oil and so forth. Happy to add it to my small pool of machinery. Anyways .... thanks for having me here.
Welcome. You did a super job. I would consider moving the grinder away from the lathe. The dust the grinder makes, can be bad for the lathe.
All the equipment will be moved. Right now I cannot open the access door to the gears due to space. The grinder will be moved to a new home. Thanks
Excellent
Cheers
Martin
Wow, that looks great!
Very nice work sir!
Outstanding sir.
Well done!
You will fit right in, go to the head of the class.
