I bought this lathe yesterday, got it mounted back on the stand and moved into my shop today. Still a bit to do before I can use it, I need to move it into a permanent spot, level it and wire an outlet. It came with a 3 and 4 jaw chuck, faceplate, drill for the tailstock, change gears, and a box full of tooling. There are two long, threaded rods that look like feed screws, but are shorter than the one on the lathe. Not sure what those are for.
I found the model 10F28 on the inside of the door covering the gears. I can't locate a data tag anywhere on the machine. Is there any way to determine the age of this thing? Not that it matters, I'm just curious. It has oil cups for the bearings in the head. Should there be a felt piece inside the oil cups, or does the oil just run straight down into the bearings?
Thanks for any help. I'm looking forward to learning on this thing.
