- Oct 31, 2015
- 23
I picked up a little Jet Mill last summer that had been sitting for several years and was in need of some TLC. The mill is a knee mill with a turret head, just a little bigger than a Clausing 8530. The spindle and quill assembles were pretty stiff, but spraying things down with some PB Blaster and squirting copious amounts of diesel fuel and 20w oil down the head oil cap loosened things up. The quill and spindle bearings freed up OK, but were rough so I disassembled the head and ordered new SKF bearings for the spindle and quill. Today I got the new bearings installed. Both assemblies are really smooth with the new bearings. Something has me puzzled though, the quill uses a pair of 7207 high angle contact ball bearings. I am wondering about how much preload should I put on these bearings. I am going to to proceed with assembling the head and can adjust final preload in situ.
I found a couple of good photo essays on rebuilds of these mills, but have not found good documentation on setting the bearing preload. Can anyone on the forum enlighten me on this?
Once I get the head assembled, I will move forward with powering up the mill. I was going to use a VFD, but am going with a rotary phase converter instead. The mill has a 1.5 hp 2 speed 3 phase motor to power the quill and uses a little 1/4 hp 3 phase motor to power the gear train of the power feed. It is my understanding that VFDs don't like that type of setup. I will post a couple of pictures in a later post.
Jim_Z
Logan 1825 lathe
Jet JVM-840PF milling machine
Jim_Z
Logan 1825 lathe
