- Mar 14, 2013
- 443
Today I replaced the column clamp bolts on my Jet JMD-15 mill/drill. The threads on the original ones were bunged up to the point that they didn't turn easily, and the motor lock screw interfered with using a box wrench (I like the old flea market offset wrench I'm using, an don't feel like tying up a socket wrench). Anyway, the original bolts are a weird 1/2-12 (yes, that's not a typo) thread, and have 13/16 head, not the normal 3/4. Somewhere I saw a writeup on using 9/16 bolts (which do have a 13/16 head), but they had to turn down the center of the bolts to clear the column, and I wouldn't be able to use the 3/4" wrench.
Instead, I bought two 12-13 studs from McMaster-Carr, along with some oversize lock nuts (which are 13/16), and some long coupler nuts (which are 3/4, so I can still use the old wrench). The long coupler nuts put the wrench outside the motor lock screw so it's not in the way (you can see it just under the upper nut). I also added some hardened thick washers I had around (though McMaster has those, too).
For those who are interested, this is what I used:
91025A740 | Black-Oxide Steel Spacing Stud, 1/2"-13 Size, 8" L Overall, 2-1/2" & 3/4" Thread Lengths | 2Each | 2 | 0 | 2.33Each | 4.66 | |
| 90977A195 | Grade 5 Zinc-Plated Steel Coupling Nut, 1/2"-13 Thread Size, 1-3/4" Length, 3/4" Width | 2Each | 2 | 0 | 4.23Each | 8.46 |
| 94827A150 | Cadmium-Plated Steel Expanding Heavy Hex Locknut, 1/2"-13 Thread Size, 13/16" Width, 1/2" Height, Packs of 5 | 1Pack | 1 | 0 | 11.89Per Pack | 11.89 |
