jet bench mill mod
T
TOOLMASTER
Forum Guest
Register Today
after 15 year I finallllllllllly made wrench nuts for the up/down head lock...dropped that socket for the last time!
turned the nuts down half way to fit 1 1/2 -1/4 wall dom..tig welded..added 1/2 x7 stainless slip handle..politely beat the crap out of the ends so they stay in ;-)
That is a great mod! If I still had my mill/drill I'd be all over that!
the first time I tried my rong fu (same thing I think) I just lightly snugged them dang nut down with the crappy wrench that came with it. haaaaa, I found out quite smartly about how tight they must be. maybe a two foot long handle would be in order. nice job.
used them a couple times now..waaaay nicer .
mine must not be getting tight enuf, im still making kidney shaped slots in 14 ga, with a 3/16 end mill. :(
more tools for the tools.. ... ....
I use a large breaker bar that i have, its very bad if the head moves on on round column mill :-0 normally involves swearing and surprise.
what have you done with the nuts on the other side?
Stuart
the other end had hex pockets for the bolt head....it doesnt take much to tighten for general milling...i'll snug up more if i'm using a fly cutter or simular
