- Jun 9, 2013
- 6
A few weeks ago I ask about a lathe here and based on feedback I bought it. After a good cleaning I realized that the automatic feed gear was missing off the end of its shaft! I was a little surprised, but happy that I found the reason why I could not get the auto feed to move. Threading seems to be fine. I have no idea when it was removed and since I bought the lathe as is I reckon it's my bag to fix at this point. I'm sure someone ran it into the head at some point and chewed up the gear. In any event I ordered and received a new gear and attempted to install it. The issue is I cannot get my fingers never mind my hands behind the apron to install the gear/key and screw in the blot/washer.
I supered glued the key to the gear and washer to the bolt so I wouldn't have to fuss with many little parts but I cannot even get the gear onto the shaft. I tried for quite a while with a long needle nose but I keep dropping the gear! I was thinking of removing the top of the carriage but again there are bolts and pins that concern me. If you have the Jet Part List GHB-1340A / BDB-1340A look on page 28 (32 in below link) the gear in question is #31 on the end of shaft D. If you look at the part book on page 34 (38 in below link) parts 11 and 8, the inside bolts will only come out a bit and then get restricted. My assumption is if I remove bolts 47 and 85 the top portion of the carriage will come off, but taper pin 84 is also a concern. Again, I'm assuming its more for alignment and if I get the bolts out I will be able to tip up on the top and it will come off...but I'm guessing here.
I have several photo that I can upload but I can't seem to figure out how, but if you take a look at the part manual you will figure you what I need to do. Here's a link to the manual: http://content.jettools.com/assets/manuals/321357A_man_EN.pdf
Thanks all
Thanks all
