- Jan 31, 2016
- 12,898
Getting into this project now and noticed something . The PO said the tractor would run with starting fluid thru the air cleaner but would not stay running . I pulled the hoods and deck off and pulled the carb off . The carb looked good as far as I could tell . I found a black wire that was cut and taped in the area . All the carbs I see on Epay have a wire to the bottom of the carb . This carb did not have a place for a wire . I'm wondering if someone cobbled this at a point ? Either way , a new carb is on the way , the new seat and battery are here and I'm ready to paint .
This is the Briggs 18hp Vanguard engine and not the Kawasaki used in the later years .
