I inherited my 4x6 saw (1981 Taiwan-made "Detroit Machinery" but pretty much the same as the HF, Jet, etc.) from my Dad, and the primary jaw, the one on the right, has a standard 9/16" bolt which tightens below the deck with a standard nut and a somewhat bent flat washer. I'm thinking this is not the OEM setup, or if it is, improvement is needed. Tightening involves reaching under the saw deck and holding the nut whilst tightening the bolt. I'm not happy with this arrangement, and was wondering about the correct setup (T-nut?) or a mod that would allow tightening without a backup. Thanks for your suggestions.
