- Apr 14, 2012
- 78
I've got an 8X18 Jet lathe with mill head made in the 1980s. The lathe uses a single phase 110 volt two speed motor that uses a capacitor to help it start under load. The electrical switch is mechanical and obviously has a forward button and a reverse button. It also has a button (longer than the f/r buttons so pushing more mechanical levers down) when pushed with either the forward or reverse button that drastically changes the geared speed (sort of like half). Here is my issue: when only pushing, say, the forward button, I get the series of geared speeds that are listed as those coming from the low speed portion of the motor. When I push the forward button along with the speed altering button, I go to about half of the lower range but pretty soon, I see smoke coming from, I believe, my motor. Does this indicate that my two speed motor has lost its high speed range? I don't want to get in a hurry to pull it out to have it rewound, if I'm just missing something. Thanks for any input. Jim
