- Dec 28, 2020
- 6
Good morning all,
In a previous thread I got great help finding specs for a replacement Rocker Shaft for my 101.21400. I was able to make the shaft of out 303 stainless and used a bench grinder to form and shape the cam surfaces. I have a 3/4 HP motor that runs at 3250.
I am going to begin assembly of the drive train this week and have run the pulley/speed calculations for the pulley set I have on hand. The result is an RPM spread of (approx) 3030 down to 740.
I have purchased a "starter set" of tooling from LittleMachineShop with OXA post, holders, index tools, boring set and a tailstock chuck.
I expect to turn mostly nylon, aluminum, soft steel and maybe some 303 stainless or brass.
If anyone can point me to a document or offer thoughts on typical speeds for a lathe of this type, size and the materials noted, I would greatly appreciate. I am certain to do a lot of experimenting and learn as I go, but any hints are always much appreciated.
Cheers,
JID
Cheers,
JID
