- Oct 31, 2016
- 2,720
My 12x36 lathe sits in front of a window in my garage. The only place where I could put it. I thought that this would be good lighting. It turns out that the light from the window is always too bright and the front side of the lathe is always dark. Hard to read the dials I have very high ceilings in my garage so hanging a light from the ceiling doesn't work. The original owner had mounted a light with a long flexible neck on the table that the lathe sits on. This light always seemed to be in the way for me and I have removed it. Lately I have been sitting a small reading lamp on the cover over the drive belts. This seems to work fairly well but you have to hang on to it at times.
Over the weekend I picked up a reading light that I could easily permanently mount on this cover by drilling 3 holes in the cover. It has a very small base.
This is the lamp.
Here it is with the base removed.
This is where I am thinking about mount the light.
I have not seen this before and am wondering if this is a dumb idea that I will later regret.
This is the lamp.
