- Nov 24, 2013
- 268
In the attached picture the vice is attached vertically to an aluminum block and I wonder if this is acceptable. The second picture shows the overall setup.
If the question is silly, as a beginner it’s normal to ask such a question but I prefer that than feel sorry later. I have never seen a vice mounted vertically.
For info, the vise is holding 2 aluminum pieces 5/8” square by 3” long and they are the arms which will hold the knurl wheels for a knurling tool I make. Since these wheels have to be aligned perfectly, they must be cut together. The partial slot cut seen on the front arm was cut when I had the pieces mounted horizontally and since I was not comfortable with that position I decide to mount them as shown.
Thank you
Nicolas
Thank you
Nicolas
