- Nov 25, 2015
- 10,046
I need to make a sleeve to adapt my Clausing 8520 to a normal Bridgeport X power feed. The bearing that came with it doesn't fit on the shaft, and rather than make a sleeve for it to fit on, I will just make a new bearing sleeve. The one they provided is not hardened as a file cuts it easily. Is 1144 Stressproof a good material to use? I can put a ground finish on it if necessary, but I suspect it might not be necessary. Can it be used as is, or do I need to heat treat it?
