IRWIN FOR NOW
riversidedan
H-M Supporter - Silver Member
Feb 17, 2021
496
started out with that HF garbage but it got me started understanding threads, picked up a IRWIN tap and was impressed so am assuming that brand is above average quality .........am now looking for a basic SAE tap/set , maybe 3/16 to 1/2 SAE set or somewhere around that.........
I like the drill/tap index. The correct drill for the tap and a tap are included. The set shown goes from a 6-32 to 1/2 , I believe.
I have sae and metric sets. I Don't remember how much but I bought them through MSC.
Oops wrong pictures
thats ok cuzz your drill/tap set looks to be functional for shop use and am still considering some Irwin basic tool sets
While I completely agree with Ulma Doc, there may be some wisdom in going with a less expensive set.
Some taps you may never, or rarely use. Others will get used extensively. Depends on the kind of work you do.
As the inexpensive/affordable taps break, replace them with the more expensive good HSS stuff.
Daryl
MN
Not adding anything but opinion and my experience. A lot depends on your work and order of operations. Get a cheap set and keep it around for "just in case" on a once in a lifetime job. Go very slowly and back it off and clean out the hole frequently. If you are cleaning up threads in a bracket and have access to the back side (through hole), chase them with a cheap tap. If it snaps, you can easily get to the nose and back it out or work it through.
Cutting six pocketed 2-56 threads in the box cam of an RG&G Gatling Gun after 10 hours of mill, lathe and bench work; use brand new the best you can buy taps. Quality taps can still break, but not as easily as junk taps. Extracting broken taps is a PITA, especially in a pocketed hole. On the plus side, if you break one off in a part you've already spent 10 hours on, the second time you make the part will probably take less than 10 hours.
I have some junk taps and have used them in brass or aluminum. But once you buy quality, you'll stick with the good stuff.
Bruce
In my experience, taps display about the absolute maximum performance difference between cheap and expensive. I have had such frustrating and untimely issues with HF type taps and even IRWIN and similar hardware store taps. I now buy only YG-1 taps, and the difference is extremely pleasing. This is hobby, it's supposed to be fun. A good tap goes a long way.
And, for more fun, get a tapping head and standardize on spiral flute taps.
I'm going toward forming taps for future stuff. We'll see how that works out.
well guys right now I look at it this way.......the lathe wasnt the best and some other things too but when I got into this told myself to "not go crazy getting the best right off which I could afford" however I got what I thought would get me started , if I stuck with it then move up but am still testing the waters........
In my experience, taps display about the absolute maximum performance difference between cheap and expensive. I have had such frustrating and untimely issues with HF type taps and even IRWIN and similar hardware store taps. I now buy only YG-1 taps, and the difference is extremely pleasing. ...
I agree. The YG-1 tap was way better than the Irwin I bought at Lowe's. But it costed almost $7. Well worth it, though, in terms of productivity.
