- Mar 10, 2012
- 125
I'm working on a project where I need to increase the internal bore on the workpiece by about .250 to .375 or so for clearance of a rotating part for about .750 to 1.0 along a length of the bore. The original bore is 2.375 inch diameter. I've made a 1 inch boring bar drilled to accept a half in round HSS bit that I hope to grind to make a wide grooving tool. Will this work? How much relief angle should I use to allow chip evacuation, etc. Or, would I be better off to make two (L&R) tools. I've had relatively little experience with internal boring etc, and would appreciate any advice. Thanks.
