- Oct 31, 2015
- 476
A couple months ago I bought a Rockwell 17" drill press at an auction. It had a funny looking and obviously non-original motor pulley on it.
I didn't pay much attention to it as I had plans to replace the motor with a treadmill motor to give me easier speed variation - especially very low speeds for drilling large holes. As it was, the lowest speed was about 650 RPM. Well today I was rearranging some things and had the DP away from the wall, so I decided to fiddle with that pulley to see if I could figure out how to get it off. The hole in the side tuned out to not contain a set screw so I got a stool to look at the top and found this:
It says "PULL GEAR, PRECISE GEAR CO, WARREN MICH" and a number: PG7 T01
The key in the center pulls out and turns to disengage the shaft from the pulley.
I played with it a little more and found that if the top portion was held stationary while the motor shaft was turned, the pulley turned at a much lower speed! So now that I knew that this was speed reducing gear rather than just a funny looking pulley, I had to figure out how the upper portion was held stationary while the DP was actually running. That's where the other non-original part on top of the DP comes in:
I turned it on and it works like a charm! Using my speed indicator that I got from forum member "WreckWreck", I determined that this devise gives a speed reduction of about 7:1. So combining with the 3 pulley steps, there are 6 speeds from 94 - 1650 RPM. Has anyone ever seen one of these? I think I'll forego the treadmill motor conversion and use it as is.
