I was going to post it, but my USED PM727 power feed was really noisy. I had to disassemble the X table as the X-nut was loose. Of course i cleaned and adjusted everything and it is SO much quieter now. I guess i could post a video, but my situation was so much worse because of the issues. Is it possible your gibs are too tight? I'm sure there will be opinions on this, but since it was apart, i replaced the thrust bearings on the x hand wheel. I then took the old and put them between the power drives lead screw adapter and the end plate on the left side of x lead screw. This helped with backlash without having to have that drive adapter grinding flat up against that lead screw plate. I'm sure you're not interested in that, I'm just pointing out what i came to do...
