Installed an X Axis Power Feed on my Bridgeport Mill
Tmate
H-M Lifetime Diamond Member
Jul 15, 2020
422
Easy to install. A couple of brackets needed to have the holes enlarged slightly. Took about an hour and a half.
Wow, something still made in the US? :)
Nice upgrade, probably last longer than the import ones
-Mark
That looks good what did you have previously on there for power feed ???
I just bought the Bridgeport 2 weeks ago. It had no power feed (other than the quill).
For the last 25 years or so I have gotten by with a 6x26 Enco knee mill. I had an Enco X axis power feed on that, and have had no problems with it. In addition to being bigger, the Bridgeport is far more complex. I'm enjoying the learning curve.
Good deal that sounds like your stepping up in the right direction!! I too have a older Bridgeport J-Head milling machine mine has the old style gear box power feed on it that I have had to work on several times in the past (I bough another power feed for donor parts) and I keep saying that the next time it breaks I’m going to get a servo type and put on . I have just never used one .did your just bolt right on or did you have to make a adapter shaft to connect to the lead screw or did you get it as a kit ??
Either way I think you’ll be pretty happy with the Bridgeport
The Servo & kit fell right on. It included everything needed. A couple of brackets had 3/8" holes that I had to run a 3/8" drill bit through to clean up. The unit cost $690.00 plus tax & shipping.
When I installed the Enco power feed on my old 6x26 mill, I had to fabricate just about everything to make it fit. This time it was a breeze.
Since you already have a power feed, your lead screw is probably different than mine. I think Servo has a different kit that addresses that.
I will have to look into that if I have anymore problems with the old style gear box one that I have now it’s great when it works but when it doesn’t it’s just a hassle to try and fix !!!! Thanks for the info
