Insertable Spade Drill in a Bridgeport?
schmidty13
H-M Supporter - Gold Member
Sep 22, 2013
61
I have a job that has become a fairly regular repeat job so I am looking for process improvements. It is drilling five 13/16" holes in 2" thick steel. The way I have been doing it is pilot hole first, then the 13/16 twist drill. I was considering investing in an insertable spade drill to reduce time and effort.
I've never used a spade drill in a manual machine, so I'm unsure if the machine has enough HP and if I can give it the feed pressure it would want. Being it's only 13/16", I would think so, but it's a big investment to make on a guess. I've just started diving into the catalog recomendations to figure it out, but was hoping I could take a short cut...anybody ever used an insertable spade on a manual mill?
I doubt very much that a BP type machine could manage a spade drill, and BTW, they do not like pilot holes. I have done a lot of drilling holes with them in my younger days.
The lack of pilot hole is why I was thinking spade...remove one operation.
The 2" depth of cut annular cutters can be expensive, but it's definitely the way to do this. I have a morse taper adapter to use them on the lathe, too, and I only wish I had done it sooner. Hours of time saved. The small contact area and large number of teeth will make quick work of these holes.
The Beaty of the annular cutter, is the spring loaded arbor, that pushes the slug out, using a 3/4“ collet, will negate that feature, I use a R8 x annular cutter adapter.
I was wondering about this. I don't want to have to stop after every hole and tap out the slug...especially since these parts have 5 holes. I just started looking, but if I use a 2" cutter, I need a 2" holder?
Another question; I will be drilling in 2" thick material...does a 2" cutter truly have 2" cutting depth? Maybe a silly question, but I don't want any surprises.
It's interesting that you don't think a Bridgeport could manage spade drills. I purchased a set a several years ago to use in my Bridgeport. So far I've only used the smaller ones, but haven't had any troubles. I must admit I believe the set I bought is a specialty set, possibly for use on a Brown & Sharpe screw machine. Some are left handed, and are ground for cutting brass.
My mill is 1 1/2 hp, but is running on a static converter, so the output is in the 1 HP range. When I do use them it's in low range, but so far they've done a good job.
Attached are a few photo's of the set. They're made by B&W Precision Products out of Detroit. They're in a fitted aluminum box that was apparently meant to be shipped through the US Mail back to the company when they needed sharpening.
How about an insert drill such as Valenite or Carbaloy ?
