I have been reading and researching, but still have questions. I have talked to some machinist's at work, and they say, use indexable inserts for the lathe. In a shop/ production setting, understandable. But they have also said that they keep HSS around for making custom bits/radius' etc. But mostly they use the inserts.
In a home shop enviorment, it is pretty much economics (IMO). HSS is cheaper, although it does take some work to get it on the lathe versus using an allen wrench. I dont want to start an argument (I have thought about posting as not to start any) rather a useful conversation.
After you get your accesories in line for the lathe, would you invest in the insert tooling? And once you do (did) do you seem to use that more or less then the HSS?
Yes I understand the importance of grinding the HSS for custom radius/ thread tools and understanding the geometry of proper clearance. Also to impress yourself :jester:
The reason I have asked this question, is it seems, the inserts seem to be getting cheaper, and Im wondering if it would be wise to invest in some. But so many choices!!! Any ways, please please dont start a fight on HSS versus inserts.
Thanks,
Chris
Thanks,
Chris
