Insert for square thread
dpb
H-M Supporter - Gold Member
I’m looking for a source for lay down inserts to cut 10 tpi square (not acme) threads. Didn’t see anything on MSC’s site.
Might not be what you're looking for but I grind my own for old single shot rifle barrels.most have square threads.brownells carries couple different square cutters.good luck..
I’ll check out Brownell’s. I have the necessary information to grind my own, was just hoping for the easy way out. Thank you.
Even if you found the inserts, you would still need the tool holder for them.
Like Lordbeezer, I've ground them from HSS. Marlin Barrels are 14 square thd/in. When it wears, re-grind or grind for retaining rings, etc.
