Initial Review of Enco 1408 Vertical Metal Cutting Bandsaw (mystery machine purchased sight unseen)
bretthl
Oct 16, 2017
341
In a previous thread (Vertical Metal Cutting Bandsaw Recommendation) Dabbler asked me to post pics and I will give my first impressions.
Disclaimer - I have never owned this type of machine so do not have a basis of comparison. I did do a lot of careful online research looking for what I thought to be the best saw in this size range. Did I nail it? Who knows. I can say though that of all the machines I own (PM935GT, PM1340GT, Wellsaw 58BW, Grizzly 1276, Ellis 9400) this machine is built to a much higher standard in terms of fit, finish and design. Everything on it is extremely well made and heavy duty. All adjustment points are high quality Allen head cap screws.
I purchased from MSC who were good to deal with and worked with my tight shipping window. The machine was fully crated in plywood and bolted to a heavy pallet base, shipped vertical, no damage. I picked it up from a local freight company and transported on my trailer horizontal with no issue.
According to the manual shipped with the machine CO is Taiwan -
The entire frame is 3/16" steel and doors are 3/32" steel. It runs whisper quite with no vibration. I am in the process of building a mobile base since I may need to move the machine for better access to my table saw.
The table is cast iron (~45 lbs), limited tilt range x and y, 19-3/4" x 19-3/4" and 7/16" thick at the thinnest point (between the web), 39" from base to table top and mounted on a cast iron trunnion -
The blade guides appear universal and adjustment is straight forward -
One of the main reasons for purchasing this machine for me was variable speed adjustment in a totally enclosed housing. The drive train appears solid and well built -
Blade speed is 80 - 300 ft/min -
The wheels are cast iron and the adjustable blade guide is a sold bar through guided by adjustable cast iron track. The blade guards are well placed and solid -
I have not used the blade shear/weld/grind feature -
The handy tension setting guide shows range 1/8" - 1" though the manual states maximum blade width 1/2".
That looks like a fantastic machine! welder and everything!
A couple of better pics of the blade guides and the table bottom.
While I was asleep the saw made its own base (well part of it). Now if the casters would ever show up I can get rolling -
Mobile base completed. I did not think I wanted a blade welder, Dabbler, but am glad I got it. I found few Lenox Diemaster2 blades on Amazon for <10USD/ea. and of course they were too long but the blade welder fixed that up for me.
