- Feb 19, 2013
- 220
Can someone explain to me how to use the numbers that are printed on a fishtail gauge used for single point threading? From what I can understand, the double depth is listed. Are these numbers used to determine how much you would need to turn in the compound at 30 degrees? Are these numbers direct reading or do you have to take the cosine of 60 degrees and multiply this by 1/2 the double depth number on the gauge?
Please explain what these numbers mean and how to use them to a novice like myself. Thanks for your time.
