- Feb 2, 2013
- 3,957
I had a flash of inspiration last week after making due with improper measuring devises
i had a job that required sleeving a worn bearing retainer
i have DTI's but the worn area in the housing was deeper than a DTI would indicate.
so i made tangential drop indicator readings because i didn't have an indirect method of making the measurements
this is incorrect, but i had to get an idea of the depth of damage, so i could consider sleeve dimensions.
i got through the job, using a .001" DTI, but the experience made me think of designs using a drop indicator for indirect measurement.
Starrett has a few different indirect measurement options like the 670A
but i wanted to design my own that would mount in an AXA holder
I designed and 3D printed a working prototype on Tinkercad.
I would like to share the inspired work with the peanut gallery
without further adieu, my abomination of indirect measurement in PLA
since i have a working prototype, i'll be copying the assembly in steel next!
thanks for reading!!!
