- Jul 9, 2014
- 613
I spent most of yesterday & the day before working my way through my must do list , rather than the to do list .
as a result I've made a simple electrolytic de -rustinmg device out of an old fashioned 12 volt batter charger , a 301 litre plastic food barrel cut in half some scrap iron bars ( Anodes ) a few " Dieseldo Onedayz..... IE " 3 inch long 40 mm gripping jaw... big crocodile 12 volt vehicle starting slave lead terminal clamps and the cable off the clamps for connections . Plus a cup full of plain old fashioned washing soda to make the electrolyte & an egg cup of washing powder all dissolved in a few cups of hot water before adding the solution to 24 gallons of tap water to help break down any grease based grime on the parts being de-rusted ..
I must say it is working well a 1930's cast iron body /sole plate wood plane has come out like new this afternoon after being in for almost 24 hrs yesterday and another 15 hrs today . Yesterday I noticed an area that had hardly been touched , scraped it & found it was thick with dust & oil/grease gunge . So ( last night ) after looking at it , I used a stiff bristled nylon brush to agitate the muck on the area ,before putting it back in the tank .
This afternoon it's as clean as a whistle . I'm leaving it in the tank till tomorrow , when I'll have a bit more time to play . For I'll hot water wash& rinse it off , then put it in the airing cupboard, to dry fairly rust free for a few hours before giving it a spray with a silicone based lubricant to seal it from the air .
I've also been spending a lot of time learning how to turn a 30 mm free cutting black steel bar x 23 inches long between centers. I don't yet have a moving steady or a fixed one that I can set up to the right height , as a result it chattered and screeched like a troop of monkeys . I spent a couple of hours resharpening the cutter , setting and constantly checking the tip height , used various speeds till I came to the conclusion that I needed " TEA ".
TEA .. Think Evaluate Act
I then set the gearing up to the smallest feed possible dropped the cutting speed as low as you can go then put in the back gear reduction. giving am RPM of around 60 turns.
Setting things up to cut to 1 thou on each pass towards the head stock ,it takes a bit of a scrape off in the reverse direction without any adjustment , using the reverse and forward gear box sent the carriage back & forth very slowly across the work piece .( must adjust the carriage gibs at the back of & under the rear carriage mounting . )
It worked well , albeit a lot slower than a French Snail on strike . there was no chatter , no screeching.and no harmonic generated scalloped like shave patterns on the bar . I must say it took me a while to use TEA and work out what was happening . Result a reasonable turned bar with both ends ( turned at the tail stock for ease of working ) the same dimensions
Now I have the axle , I am to make two large and two smaller solid 44 mm wide Delrin plastic wheels , then do some wood work to set the wheels up , one small centrally at the back , the two large ones in the middle almost as wide apart as the axle is long , the other small one central at the front like the rear one.
What's this strange beasties for ?
Moving heavy machinery out of a building , taking it 20 yards into another part then moving nine cast iron based 22" long work piece wood working lathes the same way & the to the same place . It will be narrow enough to go through all the three doors there and to allow it to turn on itself to negotiate a couple of tight right angle turns too .
the big wheels are the main mot9oion wheels the smaller ones at the back and front are to allow it to tip a little with out mishap to help us negotiate a couple of changes in walkway heights and a four inch high foot way kerbstone edge .
Piccies to follow .... If I can find where I left my camera
