- Nov 5, 2019
- 233
If you guys own one of these it’s probably not one your most prized possessions. They do have some problems. I had three choices:
Use it as is (not really an option)
Throw it out (too cheap to do that)
Try and fix it
I tried to fix it. The first thing was to mill a grove in the upper portion of the blade holder slot to accommodate the P-type parting blades. I then added a piece of 1/4” wall aluminum angle along with a brass gib to keep things aligned when tightening the wedge. It actually worked quite well. I can part aluminum, mild steel and stainless using the power feed if I want to. The Atlas feed is really too fast for that but it does work. It was a cheap fix using stuff laying around. Some day I might upgrade to the insert type holders but this works great for now.
Try and fix it
