I have a Colchester Student 1800 lathe with metric setup but which also does screw cutting for either metric or imperial. When I tried to set up for a ACME thread cut yesterday, I geared up for a 5TPI cut and did a test run. Easy peasy. But, when I went back to take a second cut (just with a highlighter for a cutter, which I often find is a cheap way to do test runs), I missed the thread.
I tried again, as I though my “old” reactions might have missed the lead screw thread dial number, but no, multiple tries give same results.
Now, the actual small lead screw/indicator dial is referenced (on it) as being metric, and the 1-4 numbers and their corresponding hit/miss graduations are all therefore calibrated with metric in mind.
So, I used the 20T gear (in the dial) and decided to hit the same number each time. It didn’t work as my second cut as mentioned was about an eighth away from the first!
After a few attempts I decided to do a “metric” cut just to see if something was loose, but this worked flawlessly. Did a course 5mm pitch and repeated it without issue using the dial on the lead screw. Went back to imperial, and no dice.
I don’t know if its age, excess of Christmas spirit (and actual spirit), or what, but for the life of me, cant see the obvious mistake I must be making.
Answers on a postcard please…..
