- Aug 29, 2019
- 1,049
I'm still impressed with the quality of the new blade I put on this little saw. It had at least a 3/32's slant to the cut with the old blade. I made zero adjustments to the saw and it cuts better than I ever expected. The channel iron is 5" and as you can tell it is clean and square . Checked with my Brown and Sharpe combination square it is very good. None of the material is de-burred yet . the little thin pieces are the ends off of material that was not square. It cuts equally as well on thin wall round tubing. No more HF blades for me. I have new HF blades and I wore myself out trying to adjust my saws to cut correctly. Not this blade it was out of the box plug and play.
