- Sep 20, 2019
- 1,394
Yesterday's project was cutting, welding, and drilling angle iron to reinforce the frame stand under my '73 Cuda. I posted the original build a year or so ago. The verticals bolted to the rear shock mounts flexed, and failure appeared imminent. The good news is I finished the job, and the fix is solid. The bad news is about 3/4 of the way through, I was too aggressive in closing a drawer in my Lyon tool chest, and something must have shifted and tripped the locking bar. Now, all of the drawers are closed and locked. I played with it for a bit unsuccessfully. It was the end of the day, and I walked away from it. It looks like it will be a project for next weekend. I never lock the box, and foolishly, I keep the keys in the top drawer, so cycling the lock is out. I doubt I could fashion a Slim Jim of sorts to reach and unlock the bar. It is a vertical bar in the cabinet's center at the back. I fear I may have to cut an access in the back to unlock it. Of course, it is against a wall, with the matching cabinet on one side and the welding table on the other. It will likely take a few hours to move things around and then jack up the cabinet enough to get the pallet jack under to move it. If you have a better idea, I'm all ears.
