- Feb 16, 2014
- 10
My dad bought an old American Tool Works lathe about 25 years ago. I have used it a few times and had a problem with the tooling chattering and the hand feed was not smooth and would skip on the teeth at times. I am going to start manufacturing some hot rod parts and decided to fix up the lathe to turn my parts with. So last weekend I took of the apron and shafts, and everything on top that moves. I cleaned everything and replaced a keyway that was almost worn in half then adjusted the cone clutch and the hand feed gear. I reassembled everything an it worked much better. I still need to tighten the slop in the cross feed.
I finally found some numbers on it while cleaning it. The number 55 is cast in the backside of the bed and also stamped into the tailstock end between the ways. The number 11 is stamped in the back side of the way and also in many other places. It looks to be an 18 speed and the threading gauge says Improved 14". This is a 5 pulley flat belt drive that has been converted to v-belts by what looks to be a set of 3 pulleys sweat on to the second largest flat pulley. It has a 4 speed car transmission with bell housing and clutch. I is driven by a 1.5 HP GE motor that I changed from 110 to 220, it seems a bit under powered and I was thinking of changing to a bigger motor, it works fine until you engage the power feed then it bogs down. I am wondering about what year lathe I have and where to find info on it. Thanks Jim
