OK, so I got myself talked into doing a "simple" favor. For reasons too numerous - and probably hilarious to people who are not me ) - I will be making some turned metal decorative knobs for some electronic equipment. No big deal, chuck in some 1" diameter steel, turn the profile, finish the top, and part it off.
Uh... it needs a 1/4" hole for the shaft in it. Oh.
OK. Face the end, center drill, drill the blind hole for the shaft, turn the profile, part it off... oh. Need to re-chuck to face the top to length and polish.
Gotta knurl a band on it too, so plumber's wax, Gorilla glue, beeswax, etc. will not hold the second clamping enough.
So I decided - no problem. Make a 1/4" stub mandrel that - um - fits in the the hole and expands a bit to hold the mostly-finished knob for doing the top.
Best I've come up with it so far is a 1" diameter round drilled through about 1/8", and the last 13/16" or so turned down to 2.49999999" and threaded inside, then split, and expanded by a... ah... closer/expander rod through the headstock
About here I decide there has to be a better way to do this. Ideas?
There's about 24 of them that need done.
