Hello All!
I am very much the amateur who is on a never ending mission to learn machine shop practices. To be honest, this process has been going on for more than a decade. (I'm a slow learner.) Now, I'm old enough to have more time to use my lathe, I can practice what I read. My lathe is a South Bend 13" from 1922 that i restored over the period of a year or more.
My recent brain storm was to perhaps buy indexable tool holders to let me take advantage of the BXA quick change tool post I have. I like to grind and use HSS tools, but sometimes I would like to be able to swap tooling without adjusting bit tip height. (I can't seem to grind tool bits to have the same height.)
The BXA's holders will take up to 5/8" tall tool shanks and will hold down to 3/8" shanks. Half inch x half inch is a perfect fit width wise. The holders are labeled "250-201" and "250-202".
As background, I mostly am using mild steel, sometimes with mill slag on it. Lots of jobs are brass. I also occasionally use stainless in one of the 300 series or even junk steel once in a while. (Lots of grounding rods have passed through my lathe- Inexpensive round stock.) If I'm lucky- 12L14 is the material.
I've read that triangle inserts are the way to go and I have also read that diamond is best shape. I surely do not know what the advantages are for either over the other.
I noticed that 3/8 inserts are less expensive than 1/2" and I am guessing they will fit into tight places easier than 1/2 but have less support at the tip.
Am I on the right track thinking about 3/8 shanks- Or, perhaps, abandon the idea all together since I don't do any production work and put the money in my "Sweetheart, we really need a milling machine" fund?
Thanks for sharing any thoughts you all have!
Paul
Paul
