Ideas for Re-Using Plate & Sheet Coupons
erikmannie
H-M Platinum Supporter
Sep 8, 2019
4,392
I use a lot of pipe welding coupons + rectangular (or square) coupons, almost all of which are carbon steel.
I already have it figured out how to re-use pipe & tubing welding coupons. After welding up the joint, I just chuck it up in the lathe, maybe cut out the HAZ, & make a fresh new pipe or tubing welding coupon.
With plate & sheet, I don’t have any good ideas. Looking at plate, I suppose one would maybe cut out the HAZ, & make a new (grooved) coupon (I do this on a milling machine). The trouble with this idea is that I don’t have a bandsaw or a cold saw, so I would be using a cutoff wheel (on an angle grinder) or an O/A cutting torch. I don’t mind having my coupons contaminated with HAZ or filler material; I cannot afford every coupon to be new material.
With sheet, I think that I would be time and money ahead to just buy new sheet coupons every time. For sheet, I like between .090” and 3/16”, & I pay the LSS to shear them because I don’t have a press brake.
I like 3” X 3” for sheet coupons. There are ways to get your money’s worth out of a bunch of squares: I start with a T-joint. Then I do another T-joint. Flip one T-joint upside down, & there is a lap joint. Do this twice, & you have a butt (or edge or corner) joint to join those together, & so on & so forth. I sure would like to know how I could do something constructive with this at the end other than scrap it. Maybe practice torch cutting & salvage a few good bits?
My main reason for making this post is to see if anybody had any ideas on how I could re-use plate coupons. The plate would probably be 1” thick & be a 6” X 6” square. This is *very* expensive material. I sure would like to buy only 1 or 2 plates, & then use them many, many times.
With my present financial situation combined with the high price of steel, I am not cutting out the HAZ.
Here is what I would like to use, but I want to make them myself:
plate coupon:
backing strip:
Here is a drawing of the HAZ:
In the drawing above, you can imagine milling down the weld bead, cutting the square perpendicular to the old weld joint, & then machining the 2 pieces to get another coupon.
I have heard that people grind off the backing strips (or “straps”). This guy uses an O/A gouging tip:
I would use a milling machine (I am not bend testing). I plan to re-use the coupon again & again.
How are you testing? When I was an apprentice, I worked on quite a lot of test coupons for welder tests: bends, reduced section tensile tests and charpy impact tests, which were for the large diameter submerged arc welds on line pipe up to 48" diameter with 1" wall thickness.
Get a bandsaw at least a portaband, you will marvel at how you got along without one all this time. My band saws get more work than any other tools in my shop because they get used on pretty much every project.
A 4x6 horizontal is not that big and will quickly pay for itself just helping you reuse that 1" plate, although you may find 5x5 coupons will be easier, 6" will tax the little saw. You could also just by 5" bar stock in varying thicknesses and cut to length. You end up paying a lot to have them cut your stock down. Locally I think it is $4 a cut so the cutting feels can quickly equal the cost of the material.
To reuse just cut between the welds and reweld until there is no open steel left.
As far as other uses... weight? I can't think of much else that a mass of weld beads would be good for. Maybe use a fly cutter to flatten it all down and start over?
The only testing that I do is visual inspection. When I machine it down, I can see if there are any missed spots.
I definitely need a bandsaw. My local steel yard charges $10/cut.
I cannot afford new steel every time. Like I said, I am not even cutting out the HAZ; as a result, a lot of my welding practice is on welding filler material.
I use an end mill to flatten down the weld bead.
On 1" coupons I started using a shaper to remove the backing. Later I used a mill. I used a 4x6 saw to cut out the side bend coupons.
I do not see any way to reclaim coupons where bend tests are required.
