The project is to make multple common parts on a mill. The parts are 2 1/4 inches long and 1 1/2 wide. They are 1/2 inch thick and have a 1/2 diameter hole in the center. The question is: What are the practical ways to set this part up for machining the edges?
The machining is on the long sides. The machineing on one long side, left side in picture, does not extend beyond the side to either end edge. However the machining on the other long side is an 'arc' that extends to both the edges. This leaves about 1/2 on each edge that is not machined, lower and upper edge in picture.
In my mind I have gotten a blamk that has the hole drilled. My first thought is to bolt the part to a mill T slot with an offset. However I do not beleive I can bolt it tight enouch to prevent the milling from causing the part to rotate.
The next thought is to make a jig that clamps to the edges that is not machined.
I have made a prototype using 2 setups. I came to the conclusion two setups should be avoded if at all possible. Any other thoughts would be appreciated.
