Not sure what these turning tools I found are for , one has a through hole in the brass disc, the other disc has a concave hole but not drilled through all the way.
The tool bit slides out as you turn the knurled knob.
Thanks in advance.
I think they are turning tools to turn small dia stock. It clamps in a qc toolholder, the brass bushing act as a guide for the matl being turned(probably why the bushing is removable allowing changes in matl dia). The cutter is adjusted via the thumb screws. Kinda like a box turning tool for a turret lathe
See post 4.
It is used like a follower rest but you bore the hole to suit the stock.
Good for a long thin shaft that you cannot get close to the chuck.
A lot of modellers/clock makers use them. They are quite easy to make and I have been thinking about one for larger diameters +5 mm as they could be more accurate than using a follower rest.
John
