- Jan 20, 2018
- 5,892
Several months ago I ran out of argon for my AHP Alpha-TIG 200x. I don't use it a lot, so it took me a while to get a replacement bottle and it was a month or two before I needed to use it. When I did, I discovered that I had suddenly lost the ability to weld. Mind you, I'm no master weldor, but I've done a quite a bit of it. I can't stack dimes, but I can stick metal together in an acceptable manner. It was impossible to get a good puddle going and the welds had serious porosity. After checking all the settings (none of which had changed) and gas flow (my hearing is not great, but I could feel the puff of gas when I hit the pedal), I decided it had to be bad/incorrect gas. My LWS was surprisingly understanding and replaced the bottle. The problem remained. I suspected the two bottles must have been filled at the same time. I borrowed a bottle of argon from a friend, the problem remained. Now I'm really puzzled and frustrated. After thinking about it for a couple of weeks I decided to try a direct connection from the flow meter to the torch, bypassing the the plumbing in the welder. It was at this point that I noticed a very slight "disturbance" in the braid covering the torch lead, right where it exited the plug on the front of the welder. Closer examination revealed that I had, at some point, bumped something into the plug and cut the gas tube. The cut was not big enough to completely cut off flow, but sufficient to prevent adequate flow and allow air into the tube. I decided to repair it, because that's what I do. Because the power lead runs inside the tube, cutting and splicing was not an option. Scrounging around in the garage, I came up with some Romex jacket about the right size. I cut a 3 in. piece and slit it lengthwise. I then slathered the inside liberally with Shoe-Goo (my current favorite), wrapped it over the braided jacket and secured it with several hose clamps.
I can weld again!
I can weld again!
