- Jan 9, 2016
- 120
I'm trying to finish up the restoration of a 40's era jointer. The pulley end of the cutter head is chewed up due to slipping setscrews and whatnot, so I intend to turn it between centers and clean it up a bit. As that part of the shaft will no longer be a standard size I'm going to need to make a pulley with a custom bore. As I understand it, the best way to do that is to mount some stock on a mandrel and turn it between centers.
So:
Should I start with a purchased mandrel and turn it down, or can I just go at it with the nearest-sized bar stock?
If I make the mandrel myself, is there a good / better /best material choice, or will plain home-center steel bar work just fine?
This will be turned on a mini-lathe with user-ground HSS tooling.
End-note: This is an experience project for me. Like many other things I do, it'd probably be a lot faster and cheaper to send this job out, but where's the fun in that? I'm just planning this at the moment; right now I need to figure out all of the things I will have to do in order to even start this project, including getting my tail stock tuned up (a job I've been putting off for a while now...).
So:
