- Apr 22, 2016
- 988
I have a external thread that measures 1.992 (18 TPI) so that should be a 2.012 nominal size (.99% of nominal). I need to make a nut to fit it. It is standard 60 degree thread.
I assume that the bore for the nut should be the same as the nominal size (2.012).
Am I right in this?
This is an odd ball size, I know but size shouldn't matter if the right relationships are maintained.
Thanks for your input
Aaron
Am I right in this?
Aaron
